Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 221 Ver todo
My I phone wont restore I try dfu mode
I try dfu mode nothing happen
Es esta una buena pregunta?
Puntuación 1
1 comentario
I noticed you never got an answer to this. Are you still having this problem?
- de
Agregar un comentario
4 Respuestas
Solución Elegida
If you put your phone into DFU mode correctly and iTunes doesn't see it, the logic board is probably dead. DFU mode will work even if half of the rest of the phone is broken :)
Fue útil esta respuesta?
Puntuación 2
I had a similar situation with a 2nd Gen. phone.
How i overcame the problem was to downgrade the firmware to 3.1.2 using redsn0w.
itunes immediately picked it up and upgraded.
Puntuación 0
Does ur phone work at all? If so, maybe u re doing smth wrong? DFU is the following: 10 sec Home+Power, the release the Power and wait for ur PC to find it...
Then (if it finds it)) Shift + Restore button it itunes and choose say 313..
thats it should be no problem..
then u can JB it and unlock with redsnow..
Best of luck=)
Puntuación 0
I say put it in Recovery mode with recboot .. its a 2 part program one to kick it into recovery mode and one to kick it out of recovery mode. use the first one and then it will show up in itunes hopefully.
Puntuación 0
Añadir tu respuesta
jemson0105 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 3,811
