Saltar al contenido principal
La Kenmore 90 Series es una lavadora fabricada por Kenmore
Preguntas 256 Ver todo
washer will not spin, replaced coupler,drive block ok motor spin
I have replaced coupler the drive block is good and the motor spins it will agitate and drain. I have also cleaned in between the basket and outer tub. Still will not spin.
Kenmore 90 Series Washing Machine model 11060802990,
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Check the drive belt. Check the door switch with a multimeter.
Clutch
If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Pulley
If the washer won't spin then the drive pulley might be worn out, seized, or damaged. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Clutch Band kit
If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Tub Bearing
If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Enter your model number to see parts for your washing machine.
Tub Seal and Bearing Kit
If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
justin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 6,004
