Saltar al contenido principal
Ordenadores de escritorio todo en uno de Apple. Los iMac estuvieron equipados con procesadores Intel entre 2006 y 2021.
Preguntas 7455 Ver todo
How do I test a display? From an iMac intel 27"?
My display came without a computer in a batch of iMac parts I purchased on eBay. How can I test this display in order to sell it?
Could I fabricate and connect it to the video output on one of my laptops? Who can guide me? If it works well, maybe I might use it on my my big machine in my workshop.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
1 comentario
Any numbers or symbols on your display that may help to identify?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
jerrypaulson, that will depend on how well you are in reverse engineering. Since you did not provide us with any information about any markings on your LCD, start with this. Get the datasheet for the LG LM270WQ1 LCD - P/N:661-5568 which is the display for the iMac 27" 2.8GHz Core i5 (A1312) - Mid 2010 from here. Check the controller pins and compare those to the computer that you are going to test it with. It will all depend on what you have to test it with, and will require you to find the proper pinouts, as well as making sure that you have a proper driver board. You will most likely not getting it connected as a second display, but you may get to test its functionality. If that is not the right panel, you will have to supply us with more information about the one you have. Remember, that even so it appears as if they are proprietary, there is other equipment that uses those panels.Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
jerrypaulson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 331
