Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.3, 2.6 o 2.7 GHz (Turbo Boost hasta 3,7 GHz) con 6 MB de caché L3 compartida.
Preguntas 561 Ver todo
Magsafe 2 Adapter Teardown for Key ring
Hey there,
anyone of you already took a MagSafe 2 to MagSafe adapter apart? Would like to have one at my key ring - so need to drill a hole through - I assume at the border in a 45° angle it would work. Anyway it would be interesting to see a teardown of the little magnet.
Some inputs?
Best regards
Mg
Es esta una buena pregunta?
Puntuación 2
1 comentario
Thanks! Nice to know people like you exist ;)
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Turns out theres a product that addresses this need. I'm not affiliated with the maker in any way, just happened to remember this question as I saw this pop up in my news feed...
Magsafe -> Magsafe 2 keyring
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
It is not easy to find an answer. Because you or somebody should sacrifice his adapter:) It's a recent thing and not easily break.
But I have an idea. Clip a cable-tie horizontally to your adapter. Cut the tie end a little longer enough to drill and hang to your key-ring. a 5 mm tie width with a 2 mm hole would be good for the purpose. I cannot add a photo but cable-tie holds the device firm enough. Maybe a drop of proper type of glue will secure more.
If you don't like it, nothing is harmed than a cable-tie!
Puntuación 1
Añadir tu respuesta
mailgoe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 2,485
