Creation of K-Lock Hole
I was thinking about drilling out a K-Lock hole in my iPad Mini. Is there a spot that would be suitable for this? i.e. Is there a spot with enough space behind it to insert a K-Lock?
Es esta una buena pregunta?
Have you looked at this solution from Kensington: Security Slot Adapter Kit for Ultrabook or this one Kensington Security Slot Adapter Kit
Here's the spec for the slot Slot Spec
The only problem I see is the thickness of the body may not be thick enough to cut you own.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 406
