My iPad screen is parshly green.
You can still see my lock and home screen, but its covered in green. Any body know how to help?
Es esta una buena pregunta?
Hi just disassemble your ipad and disconnect your lcd cable, then reconnect it back, did this happen after a fall?, most probably the connector is loose or worst its the lcd cable, hope that helps cheers!!
Fue útil esta respuesta?
Hi have you tried the solution i suggest to you?, btw just for future use, try to tape the lcd connector point so that it does not come loose again, cheers!
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 397
