Is the A1369 MBA logicboard from early 2011 compatible with late 2010?
My 13" MBA late 2010 logicboard apparently is damaged and I need to change it. I took it out and tried to clean it but it didn't make a difference.
Since I was thinking of buying a 4gb version I noticed in your guide all the connectors as well as screw positions seem identical to the 2011 model (except the keyboard light which wouldn't be used anyway)
Can it be used this way? Does the IO board cable connector which supports Thunderbolt in the 2011 poses any issues if used with the 2010 IO board?
Is the bluetooth module compatible?
Worst case scenario if you think I should give it a go, I would buy a 2011 logicboard, try it and if it doesn't work I would try to resell it, but obviously that only works if it doesn't get damaged somehow...
Thank you for your time and all the invaluable info you share.
Es esta una buena pregunta?
