system will not read games
My DS says there is no game inserted when I try to start a game. It does this with any game. And I have made sure each time it was insert correctly and completely.
Any help ?
Es esta una buena pregunta?
Any help ?
Hi, u need to check whether the pins are not bend and they are fine. Also if check if there is any corrosion on them and clean them with isopropyl alcohol. If the pins are bent then u will need to replace the card reader slot. U can get the slot from ebay and there are videos on how to replace the slot on youtube. Watch them a couple of times to make sure you are comfortable with each step. Write back on what u did. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 425
