Drivers inside door handle broke?
The plastic door handle on the driver inside door broke not allowing the door to be opened from the inside; only opened from the outside handle. Thank you for your help.
Es esta una buena pregunta?
Peter, this write up should help you getting it accomplished. Hope this helps, good luck.
Fue útil esta respuesta?
Dieselgeek has a fix for broken or cracked New Beetle door handles. They also have a bunch of helpful YouTube videos for the install process. Check em out.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,291
