Saltar al contenido principal
PC portátil de Dell con una pantalla de 15,4". Sucedió a la Inspiron 1520.
Preguntas 20 Ver todo
Laptop not turning On when pressing power Button
When I press on Power Button only the media player touch LED blinks once and the light for caps and numlock continuously blinks even I can see power on DVDROM and fan too moves . But none of the LED in front blinks and no power on monitor is there.
Could you please suggest me what should I do.
Es esta una buena pregunta?
Puntuación 2
2 comentarios
can you attach an external monitor and see if you get anything? Any post beep's?
- de
Use this : Dell AC Adapter LA90PM130
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Thanks for your Suggestion "oldturkey03"
I have troubleshooted it and found the reason, its because one of my RAM has gone Bad.
Regards,
Amit Lal
Fue útil esta respuesta?
Puntuación 0
Some times the Heat sink & fan gets dust and due to which system gets heated.
Once cleaned can help overheating & abnormal switching off issue.
Puntuación 0
Añadir tu respuesta
Amit Lal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 4,029
