How to rise car suspension
Hi
I recently purchase Caprice 2004 LTZ. I want to rise the body on car little higher. So may i know, how to rise body on suspension about 10-20 cm.
Thanks
Es esta una buena pregunta?
Hi
Thanks
Your coils springs may need some replacement due to its age. Or you can add some rubber lifter to lift the area you want.
Fue útil esta respuesta?
Another thing to check is the shock absorbers once the shocks becomes busted the end result would be a bumpy and uneven height.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 889
I know this is an old question but be careful raising the suspension of a car without a solid diff. As these cars usually have live rear axles, raising them without a correct kit as Old Turkey suggested will cause binding of your axles. Resulting in tyre wear, suspension issues and not to mention handling problems.
- de sm_vulkus
