Saltar al contenido principal
También conocida como "PS2", esta es una consola de la sexta generación de consolas para videojuegos, lanzada por Sony en Japón en Marzo del año 2000. Estados unidos recibiría su lanzamiento a finales del año 2000, con el modelo SCPH-3000. Reparar esta consola requiere simplemente herramientas comunes, de todas formas puede ser un poco complicado.
Preguntas 186 Ver todo
Why has my screen changed to black and white
For some reason the playstation 2 is in black and white only. We tried to plug something else into the connection on the TV and it was fine but the playstation is still only black and white.
Es esta una buena pregunta?
Puntuación 9
6 comentarios
i have a similar problem with my ps2, however I bought a aftermarket cable, would this cause it to show black and white?
- de
after playing game for sometime by pendrive graphics become un-understandable why???
- de
Thanks a bunch, it works!
- de
I have this problem, but I have the slim version, is there a difference? and I have a weird tv, that does not have the normal yellow, white and red holes for the cables, but video works, and sound just fine, but no color.
- de
Everytime i play f1 2006, richard burns rally, and a few other game on my ps2 my tv screen just black and white but if i play other games like gran turismo 4 original japan, and nfs underground 2 it has colours.
- de
Mostrar 1 comentario más
Agregar un comentario
4 Respuestas
Solución Elegida
Tara, depends on how you have your PS2 connected. If you are using the component cables, check in the system settings and check if its in regular RGB. If you use the regular Yellow, Red and White cables, it should be in RGB mode.
Fue útil esta respuesta?
Puntuación 2
8 comentarios:
this didnt help me but my PS2 is in RGB mode already
- de
Is ur ps2 modded
- de
Now it won't let me view system settings it will only play movies n is still in black and white now I can't change it back from RGB that what's it normally was
- de
i needed to change my tv to the AV channel instead of the component channel also to fully fix this issue
- de
Thank you halo117ish
- de
Mostrar 3 comentarios más
Respuesta Más Útil
I was having the same problem but I changed my input from component to AV and that worked.
Puntuación 11
14 comentarios:
I did exactly what you said and it works! Tq tq tq
- de
Me too!!! Thanks a bunch! Putting on AV worked :D
- de
Thanks a bunch, it worked!
- de
How can i change my input to av ?
- de
Just go to input it should be right on your remote for the TV and then you should see AV as one of the options then push the up or down arrow to go to the AV option the once you are on it the push select that's the button that says select on it yeah you just push that button.Thats it.
- de
Mostrar 9 comentarios más
This one is problem on the HDTV with tons of features in it. First go to your TV's settings and open option (in my case I'm using 50" Sharp Aquos 1080p), if you don't find it check something similar to above. Then, you want to change the "Input Select" from "Component" to "Video." This will change the color system automatically as "Component" label are for newer devices and sometimes can't cope with older devices such as PS2. After you've done it you might see the "Colour System" option and that's where colour calibration option exist. My TV sets itself to NTSC 3.58 where as the component shows 480i(with monochrome color).
Puntuación 3
2 comentarios:
Thank you this helped a lot
- de
That was exactly what fixed my issue.
thank you!!
- de
My tv is sony how can do this
Puntuación 0
Añadir tu respuesta
Tara estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 52
Ultimos 7 días: 381
Ultimos 30 días: 1,686
Todo El Tiempo: 225,534
