Saltar al contenido principal
Modelo A1001 o A1025 / procesador 667, 800, 867 o 1.0 GHz G4
Can I use a 800 mhz DVI logic board
I have a PowerBook G4 667 mhz DVI 15 inch with a bad logic board. Can I replace it with a 800 mhz DVI 15 inch logic board? are they interchangeable? Also, what about switching display assemblies from one to the other?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Yes, you can put a 800 MHz DVI board in a 667 MHz machine, but it is recommended to also install a secondary fan as well (the 667 MHz machines do not have the secondary fan). As for the displays, DVI displays are also interchangeable. You cannot, however use earlier Titanium model displays (Mercury or Onyx machines).
Good luck!
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
I knew you would know. Can he also go to the 1000 MHz board? +vote
- de
yes! but he would need a different secondary fan.
- de
Where does a Powerbook G4 Titanium DVI 867 secondary fan plug in?
Please reply to RHBernard@gmail.com of 203-984-2070
- de
You may be in luck. There are four logic boards listed for the G4 Titanium. A 667, 800, 867 and a 1000. Ben Eiseman is the parts man around here. He should be able to tell you in the morning which ones will work. Here's the boards: http://www.ifixit.com/Mac-Parts/PowerBoo...
Puntuación 0
Añadir tu respuesta
robert owen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 967
