Introducción
Replace the adhesive securing the front panel to the rear case of your iPad 2 CDMA.
Before you begin peeling and sticking tape, it's important to have clean adhesion surfaces on both the front panel and the rear case. Use a spudger to scrape off any large excess bits of original adhesive, then clean all of the gluing surfaces with a paper towel and rubbing alcohol or Goof Off.
Throughout this procedure, it is recommended to peel up each adhesive strip as needed.
Qué necesitas
Carefully peel off the first trapezoidal adhesive strip.
25 personas más completaron esta guía.
Un comentario
grazie senza di voi non avrei saputo neanche da dove iniziare invece con voi o cambiato il pannello frontale crepato del ipad 2 model 1395 ancora grazie le vostre guide sono perfette
