Introducción
Ahorra dinero reemplazando tu pantalla con una malla con esta guía. Esta guía asume que ya has quitado la malla y la ranura antiguas.
Qué necesitas
Coloque la puerta mosquitera sobre una superficie completamente plana. Coloque la nueva mosquitera sobre el marco.
Utilice cinta o abrazaderas a lo largo del borde inferior de la pantalla para mantenerla tensa contra el marco.
Para volver a ensamblar el dispositivo, siga estas instrucciones en orden inverso.
18 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Angel nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
9Guía Comentarios
really helpful; my problem is i have huge lanai windows that need to be rescreened; its very daunting because you cannot lay them down, you are working in mid air; the basic principles here will apply but how do you get started. Even just tucking the screen back in where its become loose is hard to do without it bagging out or sagging here and there. Thanx, will help when I do the door.
Start with the top side!
nicO -
Really helpful guide, thanks! I made an edit to omit the part about making sure the small squares in the mesh align with the frame because (as I experienced in my case) the mesh wasn't cut perfectly parallel, so there wasn't enough overlap if I aligned them this way. I think the most important part is to just make sure there's enough overlap on all sides.
Nice article. Thank you for sharing this. Its really helpful. Step by step instruction on door replacement is good. We expect more from your side
