Introducción
This guide will show you how to access and replace the scanner head on your HP PSC 2410 Photosmart All In One Printer.
Partes
No se requieren partes.
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Agregar Comentario
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel. Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Agregar Comentario
Press down on the two plastic hinges to remove the upper portion of printer. Press down on the two plastic hinges to remove the upper portion of printer.
  • Press down on the two plastic hinges to remove the upper portion of printer.
Agregar Comentario
To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
  • To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
Agregar Comentario
Rotate the printer so the paper tray is facing towards you. Gently lift the scanner tray up and away from the printer.
  • Rotate the printer so the paper tray is facing towards you.
  • Gently lift the scanner tray up and away from the printer.
  • Press the gray plastic tabs inward toward to release the tabs from the printer.
Agregar Comentario
Returning to the back of the printer, remove the scanner from the back hinges.
  • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
It would be easer to do steps 7 & 8 before step 6.
Richard Scott - Contestar
Gently grasp and unplug the two white ribbon cables from the printer body.
  • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
Agregar Comentario
Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
  • Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
Agregar Comentario
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
  • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Agregar Comentario
Detach the white ribbon wire from the scanner head by pulling gently at the connection. Detach the white ribbon wire from the scanner head by pulling gently at the connection.
  • Detach the white ribbon wire from the scanner head by pulling gently at the connection.
Agregar Comentario
Lift the gray drive belt from the black tab to disconnect the drive belt from the scanner head. Remove the scanner head from the scanner by gently rotating and then lifting.
  • Lift the gray drive belt from the black tab to disconnect the drive belt from the scanner head.
  • Remove the scanner head from the scanner by gently rotating and then lifting.
Agregar Comentario
Place the new scanner head in the scanner tray by fastening the drive belt into the black tab. Make sure the tab on the outer portion of the gray drive belt is fastened.
  • Place the new scanner head in the scanner tray by fastening the drive belt into the black tab.
  • Make sure the tab on the outer portion of the gray drive belt is fastened.
  • Once the drive belt is secured, rotate the scanner head back into position.
  • Re-attach the white ribbon wire to the connection from Step 10.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 12-31, Maness Spring 2011 Miembro de Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Miembros
9 Guías creadas
Ok, but where do I purchase a new scanner head???
Nichelle King - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 10
Últimos 30 Días: 54
Todo El Tiempo: 9,862
