Introducción
Make sure you look at the Samsung P241 Troubleshooting Guide first to see if you can solve your problem without taking the DVD player apart.
If the button panel is broken a replacement button panel will need to be purchased.
You will need to be near a power source for this  guide. With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
  • You will need to be near a power source for this guide.
  • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
Agregar Comentario
Pull the top cover towards you until you can lift it up and off. Pull the top cover towards you until you can lift it up and off.
  • Pull the top cover towards you until you can lift it up and off.
Agregar Comentario
With the front of the DVD player facing you, turn the power on and eject the disc tray. Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover.  The cover should easily pop up and off the disc tray.
  • With the front of the DVD player facing you, turn the power on and eject the disc tray.
  • Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
  • Be careful not to crack or bend the disc tray by pulling too hard.
Agregar Comentario
To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player. Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off. If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
  • To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player.
  • Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off.
  • If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Gently remove the front panel by pulling it forward.
  • Gently remove the front panel by pulling it forward.
Agregar Comentario
Press the eject button again to make the disc tray slide back into place.
  • Press the eject button again to make the disc tray slide back into place.
  • Turn off the DVD player and unplug it from the wall before proceeding to further steps.
Agregar Comentario
Holding the front panel so the Samsung logo is visible, rotate the panel to view the opposite side. Holding the front panel so the Samsung logo is visible, rotate the panel to view the opposite side.
  • Holding the front panel so the Samsung logo is visible, rotate the panel to view the opposite side.
Agregar Comentario
Locate the button panel on the inside towards what is now the right of the front panel. Locate the button panel on the inside towards what is now the right of the front panel.
  • Locate the button panel on the inside towards what is now the right of the front panel.
Agregar Comentario
To unjam a button, use a finger or flathead screwdriver, and firmly press against the jammed portion of the button panel.
  • To unjam a button, use a finger or flathead screwdriver, and firmly press against the jammed portion of the button panel.
  • Press until the button slides back into it's designated button slot.
Agregar Comentario
If the button panel is broken, use a flathead screwdriver to pry the button panel from the back of the front panel.
  • If the button panel is broken, use a flathead screwdriver to pry the button panel from the back of the front panel.
  • With strong plastic adhesive, glue the new button panel into place with each button in it's designated button slot.
  • Allow the adhesive time to properly dry before pressing buttons.
Agregar Comentario
If the button panel is not the cause of the problem, the button sensors on the motherboard need to be replaced.
  • If the button panel is not the cause of the problem, the button sensors on the motherboard need to be replaced.
  • You can refer to this guide for directions on how to solder new sensors on your motherboard if you don't want to replace the entire motherboard.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Matt Russell
Miembro Desde 14/01/11
116 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-7, Forte Winter 2011 Miembro de Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 893
