Saltar al contenido principal
Samsung Galaxy Tab S2 8.0 Battery Replacement
Qué necesitas
  1. Samsung Galaxy Tab S2 8.0 Battery Replacement, Screen: paso 1, imagen 1 de 1
    • Working on a device that is turned on may yield an electric shock. Make sure your device is turned off before working on it.
    • Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 2, imagen 2 de 2
    • Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
    • Put an opening pick in the gap created, in between the screen and the panel.
    • Repeat all around device, putting 2 picks on top and bottom, and one on each side.
  3. Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 3, imagen 2 de 2
    • Carefully remove the small suction cup from the corner without moving the screen.
    • Place the small suction cup in the center of the screen and lift to remove screen.
    • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
    • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
  4. Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 4, imagen 1 de 1
    • Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
    • Carefully lift the plastic opening tool to detach the ribbon from the tablet.
    • Make sure to discharge any static electricity by touching a grounded metal object, like a quarter, before touching the inside of the device.
  5. Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 5, imagen 1 de 1
    • The screen is now detached from the rest of the tablet.
  6. Samsung Galaxy Tab S2 8.0 Battery Replacement, Battery: paso 6, imagen 1 de 3 Samsung Galaxy Tab S2 8.0 Battery Replacement, Battery: paso 6, imagen 2 de 3 Samsung Galaxy Tab S2 8.0 Battery Replacement, Battery: paso 6, imagen 3 de 3
    • Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
    • Lift up and remove the panel of the board using a plastic opening tool.
  7. Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 7, imagen 1 de 1
    • Remove the cable that connects the battery and device using the plastic opening tools.
  8. Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab S2 8.0 Battery Replacement: paso 8, imagen 2 de 2
    • You can now safely remove the battery from the device by lifting it from the paper flap.
Conclusión
15 personas más completaron esta guía.
Jonathan Wood
Miembro Desde 04/18/17
1,011 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S17-G1, Banghart Spring 2017 Miembro de Cal Poly, Team S17-G1, Banghart Spring 2017
CPSU-BANGHART-S17S17G1
5 Miembros
15 Guías creadas
15 comentarios
Does the adhesive behind the screen get messed up during opening, or does it stay together enough to re-bond as before?
jaspchew - Contestar
Humm u’ve just had to remove the back cover the battery is here no need to remove the screen
Thomas Fuentes - Contestar
OMG thank you I definitely would have followed the instructions you’re absolutely right the back just case clips and comes off fairly easy
Jessica Pickering -
Thank you. OH GOD thank you.
larissap112 -
This isn’t true with this model. You have the Exnyos one. The Qualcomm one does not have a removable back..
JM M -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 99
Todo El Tiempo: 25,019
