Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 3
Carefully remove the small suction cup from the corner without moving the screen. Place the small suction cup in the center of the screen and lift to remove screen.
  • Carefully remove the small suction cup from the corner without moving the screen.
  • Place the small suction cup in the center of the screen and lift to remove screen.
  • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
  • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
Insertar traducción aquí
