Saltar al contenido principal
Samsung Galaxy S5 Battery Replacement
Qué necesitas
  1. Samsung Galaxy S5 Battery Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy S5 Battery Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy S5 Battery Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Battery Replacement, Battery: paso 2, imagen 1 de 3 Samsung Galaxy S5 Battery Replacement, Battery: paso 2, imagen 2 de 3 Samsung Galaxy S5 Battery Replacement, Battery: paso 2, imagen 3 de 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Conclusión
83 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,822 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,141 Guías creadas
10 comentarios
This is too complicated :(
Jaydon - Contestar
I replaced the battery in my phone because it drained fast, and drained completely in any temp below 50, I put the new battery In but when I try to turn it on the farthest I get is the screen that says "Samsung galaxy s5" help?
mw - Contestar
Do I also need to remove the sim card? Or can I just put a new battery in?
nancysapone - Contestar
Thanks am replacing glass as well...easy to get the battery and sim out.
rob taylor - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 57
Ultimos 30 días: 229
Todo El Tiempo: 95,462
