Saltar al contenido principal
Samsung Chromebook 3 Motherboard Replacement
Qué necesitas
  1. Samsung Chromebook 3 Motherboard Replacement, Bottom Case: paso 1, imagen 1 de 2 Samsung Chromebook 3 Motherboard Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Motherboard Replacement: paso 2, imagen 1 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 2, imagen 2 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Motherboard Replacement: paso 3, imagen 1 de 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Motherboard Replacement, Battery: paso 4, imagen 1 de 2 Samsung Chromebook 3 Motherboard Replacement, Battery: paso 4, imagen 2 de 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Motherboard Replacement: paso 5, imagen 1 de 2 Samsung Chromebook 3 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Motherboard Replacement: paso 6, imagen 1 de 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: paso 7, imagen 2 de 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: paso 7, imagen 3 de 3
    • Before you can get to the motherboard, remove the three 4.6mm screws from the port cover using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 Motherboard Replacement: paso 8, imagen 1 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 8, imagen 2 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 8, imagen 3 de 3
    • Then, use a spudger to begin flipping up the grey covers on the ZIF connectors.
  9. Samsung Chromebook 3 Motherboard Replacement: paso 9, imagen 1 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 9, imagen 2 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 9, imagen 3 de 3
    • Two more ZIF connectors to go!
  10. Samsung Chromebook 3 Motherboard Replacement: paso 10, imagen 1 de 2 Samsung Chromebook 3 Motherboard Replacement: paso 10, imagen 2 de 2
    • Use a spudger to disconnect the cables going to the speaker by prying outward to the right.
  11. Samsung Chromebook 3 Motherboard Replacement: paso 11, imagen 1 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 11, imagen 2 de 3 Samsung Chromebook 3 Motherboard Replacement: paso 11, imagen 3 de 3
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Then gently coax the display cable from its connector using your fingers or a spudger.
  12. Samsung Chromebook 3 Motherboard Replacement: paso 12, imagen 1 de 2 Samsung Chromebook 3 Motherboard Replacement: paso 12, imagen 2 de 2
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
  13. Samsung Chromebook 3 Motherboard Replacement: paso 13, imagen 1 de 1
    • Ensure all cables are clear and remove the motherboard.
Conclusión
4 personas más completaron esta guía.
Austin Blakely
Miembro Desde 03/11/19
19,536 Reputación
53 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,198 Guías creadas
Un comentario
Thanks for the great guide! I used it to remove the write protection screw on the back of the motherboard.
My Chromebook is model number XE501C13. The only difference I noticed is that there is one less screw on the outer plastic cover. Everything else is exactly the same!
Edward Fernandez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 33
Todo El Tiempo: 2,935
