Saltar al contenido principal
Razer Blade RZ09-0102 Battery Replacement
Qué necesitas
  1. Razer Blade RZ09-0102 Battery Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Battery Replacement, Battery: paso 2, imagen 1 de 2 Razer Blade RZ09-0102 Battery Replacement, Battery: paso 2, imagen 2 de 2
    • Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
  3. Razer Blade RZ09-0102 Battery Replacement: paso 3, imagen 1 de 1
    • Unlock the ZIF connectors securing the right ribbon cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Carefully pull the two ribbon cables out of their sockets.
  4. Razer Blade RZ09-0102 Battery Replacement: paso 4, imagen 1 de 1
    • Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
  5. Razer Blade RZ09-0102 Battery Replacement: paso 5, imagen 1 de 2 Razer Blade RZ09-0102 Battery Replacement: paso 5, imagen 2 de 2
    • Carefully pull out the two connectors out of their sockets.
    • Pull parallel to the motherboard, not straight up.
  6. Razer Blade RZ09-0102 Battery Replacement: paso 6, imagen 1 de 2 Razer Blade RZ09-0102 Battery Replacement: paso 6, imagen 2 de 2
    • Pull the wide battery connector towards the battery to disconnect it from the motherboard.
  7. Razer Blade RZ09-0102 Battery Replacement: paso 7, imagen 1 de 2 Razer Blade RZ09-0102 Battery Replacement: paso 7, imagen 2 de 2
    • Remove the battery from the laptop.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
6 personas más completaron esta guía.
2 comentarios
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
Erfan Moradi - Contestar
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
Giorgi Kikuashvili - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 53
Todo El Tiempo: 26,037
