Introducción
Replacing the pulsing white LED sleep indicator.
Use a coin to turn the battery locking screw 90 degrees to the right.
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
Agregar Comentario
Remove the four Phillips screws from the memory door.
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
Agregar Comentario
Remove the long black Phillips screw next to the memory card.
  • Remove the long black Phillips screw next to the memory card.
  • Remove the small EMI finger beneath the black screw.
Agregar Comentario
On the keyboard, remove the F1, F2, F11, and F12 keys.
  • On the keyboard, remove the F1, F2, F11, and F12 keys.
  • This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
  • You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
  • When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
Agregar Comentario
Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
  • Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
Agregar Comentario
Remove the two short Phillips screws.
  • Remove the two short Phillips screws.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
  • Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
Agregar Comentario
Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
  • Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
Pull straight up, not sideways. I used tweezers on the connector, rather than pulling on the ribbon cable.
vmile - Contestar
mine had foil tape over the connector
Avi Fagan - Contestar
Carefully lift edges of foil tape across logic board connector end of keyboard cable (foil is present if unit
has not been apart before).
Grasp cable near the connector and gently pull straight up (perpendicular to logic board).
John Haruguchi - Contestar
Remove the three small Phillips screws from within the battery compartment.
  • Remove the three small Phillips screws from within the battery compartment.
Agregar Comentario
Turn the computer 90 degrees clockwise and remove the two medium-length Phillips screws from the casing.
  • Turn the computer 90 degrees clockwise and remove the two medium-length Phillips screws from the casing.
Agregar Comentario
Turn the computer 90 degrees clockwise again, and remove only the bottom screw on either side of the hinge.
  • Turn the computer 90 degrees clockwise again, and remove only the bottom screw on either side of the hinge.
By bottom screw, it means the screw nearer the lid, not the screw nearer the bottom of the computer
cantoi - Contestar
Turn the computer 90 degrees clockwise just one more time, and remove the two Phillips screws on the exterior wall of the battery compartment.
  • Turn the computer 90 degrees clockwise just one more time, and remove the two Phillips screws on the exterior wall of the battery compartment.
  • Remember these two screws are longer and have shoulders.
Agregar Comentario
Turn the computer over and open it up.
  • Turn the computer over and open it up.
  • Remove the following 14 screws:
    • Six 2.5 mm Phillips on either side of the keyboard area.
    • Five 4.5 mm Phillips on the left half of the keyboard area.
    • One 7 mm hex in the upper left corner of the upper case (a T6 Torx driver will do the job nicely).
    • One 15 mm Phillips in the upper middle of the keyboard area.
    • One 16.5 mm hex in the upper right of the upper case (again, a T6 Torx driver will work well).
Agregar Comentario
Peel up the two pieces of foil tape on the left side of the keyboard area.
  • Peel up the two pieces of foil tape on the left side of the keyboard area.
  • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
  • Carefully disconnect the microphone and power cables from the logic board. Using your fingernails or a dental pick, carefully pry the connectors from their sockets. Make sure you're pulling only on the connector and not on the socket.
At least on my own PowerBook G4 12” 867MHz, the microphone and power cables are long enough that I was able to do the hard drive replacement without disconnecting those connections. I basically had to flip the top case over to the left rather than removing it straight upward. I guess that makes some of the subsequent steps slightly tricky, but at least for me, the tradeoff was worth it.
Barry Nathan - Contestar
Use the orange plastic loop to disconnect the trackpad cable.
  • Use the orange plastic loop to disconnect the trackpad cable.
Agregar Comentario
Starting at one of the upper corners near the screen, work around the frame, separating the upper case from the lower case.
  • Starting at one of the upper corners near the screen, work around the frame, separating the upper case from the lower case.
Agregar Comentario
Lift the upper case off the computer.
  • Lift the upper case off the computer.
can't lift upper case off. upper case.. it anchored on display side !!!
Fernando - Contestar
Remove the single Phillips screw securing the sleep light to the latch mechanism.
  • Remove the single Phillips screw securing the sleep light to the latch mechanism.
  • Lift the sleep light out of the computer.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 3,046
