Introducción
Removing the heat shield enables access to the RAM and the processor below.
Turn the computer so that the ports are facing you.
  • Turn the computer so that the ports are facing you.
  • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Agregar Comentario
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • In order to replace the keyboard, you must first remove the modem.
Agregar Comentario
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Agregar Comentario
Lift the heat shield up and pull it toward you.
  • Lift the heat shield up and pull it toward you.
Agregar Comentario
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 2,187
