Introducción
Removal of the track pad panel is necessary to reach the hard drive and track pad.
Partes
No se requieren partes.
Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
  • Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
Agregar Comentario
Press and hold the button on the left of the front side and slide the battery out. Press and hold the button on the left of the front side and slide the battery out.
  • Press and hold the button on the left of the front side and slide the battery out.
Agregar Comentario
With a T8 torx screwdriver, remove the three 24mm torx screws along the middle of the back panel.
  • With a T8 torx screwdriver, remove the three 24mm torx screws along the middle of the back panel.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Turn the computer over and open the display. You should see that the keyboard is loose. Before attempting to remove the keyboard, note that a ribbon cable connects  the keyboard to the logic board. Improper removal may damage your keyboard. Carefully lift the front of the keyboard up slightly and then slide the keyboard towards yourself.
  • Turn the computer over and open the display. You should see that the keyboard is loose.
  • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
  • Carefully lift the front of the keyboard up slightly and then slide the keyboard towards yourself.
  • Then carefully lift the top half of the keyboard and rotate it towards yourself.
Agregar Comentario
Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port. Gently remove the ribbons from its tabs
  • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
  • Gently remove the ribbons from its tabs
Agregar Comentario
Gently wiggle the RAM card to loosen the connection until it pulls free. Gently wiggle the RAM card to loosen the connection until it pulls free.
  • Gently wiggle the RAM card to loosen the connection until it pulls free.
Agregar Comentario
Push the display screen back to give yourself enough space to remove the side panels.
  • Push the display screen back to give yourself enough space to remove the side panels.
  • Before removing the side panels, note that removing the side panels hastily will damage the underlying panel screw. However, this will not affect the functionality of your PowerBook.
  • Remove the panels on either side by gently but firmly pulling up on them with both hands.
Agregar Comentario
Use the plastic opening tool to lift up the tabs on either side of the ribbon cable port and then gently pull the ribbon cable free. Use the plastic opening tool to lift up the tabs on either side of the ribbon cable port and then gently pull the ribbon cable free.
  • Use the plastic opening tool to lift up the tabs on either side of the ribbon cable port and then gently pull the ribbon cable free.
Agregar Comentario
WARNING: There is a high risk of breaking the tabs that lock the panel to the casing. Remove the panel slowly and cautiously to avoid damage. With your index finger and your thumb, squeeze the track pad panel to loosen the clamps. Then slide the panel towards yourself. With your index finger and your thumb, squeeze the track pad panel to loosen the clamps. Then slide the panel towards yourself.
  • WARNING: There is a high risk of breaking the tabs that lock the panel to the casing. Remove the panel slowly and cautiously to avoid damage.
  • With your index finger and your thumb, squeeze the track pad panel to loosen the clamps. Then slide the panel towards yourself.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 24-59, Amido Spring 2011 Miembro de Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,020
