Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 2
Turn the computer over and open the display. You should see that the keyboard is loose. Before attempting to remove the keyboard, note that a ribbon cable connects  the keyboard to the logic board. Improper removal may damage your keyboard. Carefully lift the front of the keyboard up slightly, and then slide the keyboard towards yourself.
  • Turn the computer over and open the display. You should see that the keyboard is loose.
  • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
  • Carefully lift the front of the keyboard up slightly, and then slide the keyboard towards yourself.
  • Then carefully lift the top half of the keyboard, and rotate it towards yourself.
Insertar traducción aquí
