Saltar al contenido principal
PlayStation Vita Right Joystick Replacement
Qué necesitas
  1. PlayStation Vita Right Joystick Replacement, Case Separation: paso 1, imagen 1 de 2 PlayStation Vita Right Joystick Replacement, Case Separation: paso 1, imagen 2 de 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Joystick Replacement: paso 2, imagen 1 de 3 PlayStation Vita Right Joystick Replacement: paso 2, imagen 2 de 3 PlayStation Vita Right Joystick Replacement: paso 2, imagen 3 de 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Joystick Replacement: paso 3, imagen 1 de 2 PlayStation Vita Right Joystick Replacement: paso 3, imagen 2 de 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Joystick Replacement: paso 4, imagen 1 de 3 PlayStation Vita Right Joystick Replacement: paso 4, imagen 2 de 3 PlayStation Vita Right Joystick Replacement: paso 4, imagen 3 de 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Joystick Replacement: paso 5, imagen 1 de 2 PlayStation Vita Right Joystick Replacement: paso 5, imagen 2 de 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Joystick Replacement: paso 6, imagen 1 de 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Joystick Replacement: paso 7, imagen 1 de 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Joystick Replacement: paso 8, imagen 1 de 1
    • Separate the front and rear cases.
  9. PlayStation Vita Right Joystick Replacement, Wireless Card: paso 9, imagen 1 de 3 PlayStation Vita Right Joystick Replacement, Wireless Card: paso 9, imagen 2 de 3 PlayStation Vita Right Joystick Replacement, Wireless Card: paso 9, imagen 3 de 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Joystick Replacement: paso 10, imagen 1 de 2 PlayStation Vita Right Joystick Replacement: paso 10, imagen 2 de 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Joystick Replacement: paso 11, imagen 1 de 2 PlayStation Vita Right Joystick Replacement: paso 11, imagen 2 de 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Joystick Replacement, Right Shoulder Button: paso 12, imagen 1 de 3 PlayStation Vita Right Joystick Replacement, Right Shoulder Button: paso 12, imagen 2 de 3 PlayStation Vita Right Joystick Replacement, Right Shoulder Button: paso 12, imagen 3 de 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Joystick Replacement: paso 13, imagen 1 de 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Joystick Replacement: paso 14, imagen 1 de 3 PlayStation Vita Right Joystick Replacement: paso 14, imagen 2 de 3 PlayStation Vita Right Joystick Replacement: paso 14, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Joystick Replacement: paso 15, imagen 1 de 2 PlayStation Vita Right Joystick Replacement: paso 15, imagen 2 de 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Right Joystick Replacement, Right Button Board: paso 16, imagen 1 de 2 PlayStation Vita Right Joystick Replacement, Right Button Board: paso 16, imagen 2 de 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Right Joystick Replacement: paso 17, imagen 1 de 2 PlayStation Vita Right Joystick Replacement: paso 17, imagen 2 de 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Right Joystick Replacement: paso 18, imagen 1 de 3 PlayStation Vita Right Joystick Replacement: paso 18, imagen 2 de 3 PlayStation Vita Right Joystick Replacement: paso 18, imagen 3 de 3
    Comprar
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Right Joystick Replacement: paso 19, imagen 1 de 3 PlayStation Vita Right Joystick Replacement: paso 19, imagen 2 de 3 PlayStation Vita Right Joystick Replacement: paso 19, imagen 3 de 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Right Joystick Replacement: paso 20, imagen 1 de 3 PlayStation Vita Right Joystick Replacement: paso 20, imagen 2 de 3 PlayStation Vita Right Joystick Replacement: paso 20, imagen 3 de 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Right Joystick Replacement, Right Joystick: paso 21, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two 5.0mm, blue screws from the right joystick.
  22. PlayStation Vita Right Joystick Replacement: paso 22, imagen 1 de 3 PlayStation Vita Right Joystick Replacement: paso 22, imagen 2 de 3 PlayStation Vita Right Joystick Replacement: paso 22, imagen 3 de 3
    • Using a spudger, gently pry the joystick out of the back casing assembly.
Conclusión
25 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
89,020 Reputación
131 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,299 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 35
Ultimos 30 días: 129
Todo El Tiempo: 29,258
