Saltar al contenido principal
PlayStation Vita Rear Panel Replacement
Qué necesitas
  1. PlayStation Vita Rear Panel Replacement, Case Separation: paso 1, imagen 1 de 2 PlayStation Vita Rear Panel Replacement, Case Separation: paso 1, imagen 2 de 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Panel Replacement: paso 2, imagen 1 de 3 PlayStation Vita Rear Panel Replacement: paso 2, imagen 2 de 3 PlayStation Vita Rear Panel Replacement: paso 2, imagen 3 de 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Panel Replacement: paso 3, imagen 1 de 2 PlayStation Vita Rear Panel Replacement: paso 3, imagen 2 de 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Panel Replacement: paso 4, imagen 1 de 3 PlayStation Vita Rear Panel Replacement: paso 4, imagen 2 de 3 PlayStation Vita Rear Panel Replacement: paso 4, imagen 3 de 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Panel Replacement: paso 5, imagen 1 de 2 PlayStation Vita Rear Panel Replacement: paso 5, imagen 2 de 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Rear Panel Replacement: paso 6, imagen 1 de 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Panel Replacement: paso 7, imagen 1 de 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Rear Panel Replacement: paso 8, imagen 1 de 1
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Panel Replacement, Battery: paso 9, imagen 1 de 2 PlayStation Vita Rear Panel Replacement, Battery: paso 9, imagen 2 de 2
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. PlayStation Vita Rear Panel Replacement: paso 10, imagen 1 de 2 PlayStation Vita Rear Panel Replacement: paso 10, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. PlayStation Vita Rear Panel Replacement: paso 11, imagen 1 de 3 PlayStation Vita Rear Panel Replacement: paso 11, imagen 2 de 3 PlayStation Vita Rear Panel Replacement: paso 11, imagen 3 de 3
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
  12. PlayStation Vita Rear Panel Replacement, Rear Panel: paso 12, imagen 1 de 3 PlayStation Vita Rear Panel Replacement, Rear Panel: paso 12, imagen 2 de 3 PlayStation Vita Rear Panel Replacement, Rear Panel: paso 12, imagen 3 de 3
    • Slide the spuder between the right speaker and the rear casing.
    • Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
    • Remove the right speaker.
  13. PlayStation Vita Rear Panel Replacement: paso 13, imagen 1 de 3 PlayStation Vita Rear Panel Replacement: paso 13, imagen 2 de 3 PlayStation Vita Rear Panel Replacement: paso 13, imagen 3 de 3
    • Slide the spudger between the left speaker and the rear casing.
    • Using a spudger, gently peel up the left speaker from the light adhesive connecting it to casing.
    • Remove the left speaker.
  14. PlayStation Vita Rear Panel Replacement: paso 14, imagen 1 de 1
    • The rear panel remains.
Conclusión
11 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
89,017 Reputación
131 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,820 Guías creadas
5 comentarios
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
Daniel - Contestar
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
I can't get pass Step 1. I can take out the bottom left screw of the rear touchpad but I can't take out the other 3. I bought a used Vita and there is a screw that turns but does not gout up. What should I do?
kken07655 - Contestar
In the part that remains after complete disassembly, what are the two double pins at the top for, which later come into contact with the motherboard? I already have a new panel, but it has absolutely nothing except this one contact in the lower right part ...
Kamil Dębiec - Contestar
Those are wifi antennas. You can get it out put it in to the new panel.
repairguy69 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 81
Ultimos 30 días: 346
Todo El Tiempo: 30,343
