Saltar al contenido principal
Patching a Bicycle Tire Inner Tube
Qué necesitas
  1. Patching a Bicycle Tire Inner Tube, Rear Wheel: paso 1, imagen 1 de 2 Patching a Bicycle Tire Inner Tube, Rear Wheel: paso 1, imagen 2 de 2
    • Flip the quick release lever on the wheel.
  2. Patching a Bicycle Tire Inner Tube: paso 2, imagen 1 de 1
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Patching a Bicycle Tire Inner Tube: paso 3, imagen 1 de 1
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Patching a Bicycle Tire Inner Tube, Inner Tube: paso 4, imagen 1 de 1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  5. Patching a Bicycle Tire Inner Tube: paso 5, imagen 1 de 2 Patching a Bicycle Tire Inner Tube: paso 5, imagen 2 de 2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  6. Patching a Bicycle Tire Inner Tube: paso 6, imagen 1 de 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  7. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: paso 7, imagen 1 de 1
  8. Patching a Bicycle Tire Inner Tube: paso 8, imagen 1 de 2 Patching a Bicycle Tire Inner Tube: paso 8, imagen 2 de 2
  9. Patching a Bicycle Tire Inner Tube: paso 9, imagen 1 de 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  10. Patching a Bicycle Tire Inner Tube: paso 10, imagen 1 de 2 Patching a Bicycle Tire Inner Tube: paso 10, imagen 2 de 2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  11. Patching a Bicycle Tire Inner Tube: paso 11, imagen 1 de 1
    • Mark the hole with a marker, and completely deflate the tire.
  12. Patching a Bicycle Tire Inner Tube: paso 12, imagen 1 de 1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  13. Patching a Bicycle Tire Inner Tube: paso 13, imagen 1 de 1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  14. Patching a Bicycle Tire Inner Tube: paso 14, imagen 1 de 1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  15. Patching a Bicycle Tire Inner Tube: paso 15, imagen 1 de 1
    • Apply the patch to the area.
  16. Patching a Bicycle Tire Inner Tube: paso 16, imagen 1 de 1
    • Apply pressure to the patch until the rubber cement is dry.
Conclusión
To reassemble your wheel, follow these instructions in reverse order starting at step three.
6 personas más completaron esta guía.
Travis Tonder
Miembro Desde 10/05/10
3,175 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 5-13, Maness Fall 2010 Miembro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 4,108
