Saltar al contenido principal
Nintendo Wii mini Disc Drive Replacement
Qué necesitas
  1. Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: paso 1, imagen 1 de 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: paso 1, imagen 2 de 2
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Disc Drive Replacement, Remove the Cover: paso 2, imagen 1 de 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: paso 2, imagen 2 de 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: paso 2, imagen 3 de 3
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: paso 3, imagen 1 de 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: paso 3, imagen 2 de 2
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: paso 4, imagen 1 de 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: paso 4, imagen 2 de 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: paso 4, imagen 3 de 3
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
  5. Nintendo Wii mini Disc Drive Replacement, Power Board: paso 5, imagen 1 de 3 Nintendo Wii mini Disc Drive Replacement, Power Board: paso 5, imagen 2 de 3 Nintendo Wii mini Disc Drive Replacement, Power Board: paso 5, imagen 3 de 3
    • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
    • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
  6. Nintendo Wii mini Disc Drive Replacement: paso 6, imagen 1 de 2 Nintendo Wii mini Disc Drive Replacement: paso 6, imagen 2 de 2
    • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
  7. Nintendo Wii mini Disc Drive Replacement: paso 7, imagen 1 de 2 Nintendo Wii mini Disc Drive Replacement: paso 7, imagen 2 de 2
    • Lift the power board from the console and set it aside.
  8. Nintendo Wii mini Disc Drive Replacement, Disc Drive: paso 8, imagen 1 de 2 Nintendo Wii mini Disc Drive Replacement, Disc Drive: paso 8, imagen 2 de 2
    • Using a Phillips #0 Screwdriver, unscrew the four 6mm screws.
  9. Nintendo Wii mini Disc Drive Replacement: paso 9, imagen 1 de 2 Nintendo Wii mini Disc Drive Replacement: paso 9, imagen 2 de 2
    • Lift the disc drive out of the console and set it aside.
Conclusión
3 personas más completaron esta guía.
Equipo
UWT Liner: Group 5 Miembro de UWT Liner: Group 5
Community
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 51
Todo El Tiempo: 4,328
