Introducción
This guide is all about installing the rumble motor. The rumble motor is responsible for the vibration you feel in your controller during certain game actions. You may want to use this guide if your controller won't rumble.
Place the controller (buttons down) on a solid surface.
  • Place the controller (buttons down) on a solid surface.
  • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Agregar Comentario
Gently lift the back panel up, separating it from the front panel.
  • Gently lift the back panel up, separating it from the front panel.
  • Some of the buttons may fall out if they are knocked around.
Agregar Comentario
Grab the Z-button by the peg with tweezers and lift it out of the controller. During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  • Grab the Z-button by the peg with tweezers and lift it out of the controller.
  • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully unhook the cable that is looped around the peg.
  • Carefully unhook the cable that is looped around the peg.
Um can soneone explain the peg and cable part? I dont understand it...
Tyler Goamez - Contestar
I would say that the cable is somehow "hooked" to the case and you have to get the cable away from the case so that you can pull out the board
My1 -
Lift the circuit board out of the controller.
  • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
Agregar Comentario
Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead. Repeat for the second lead and wire.
  • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
  • Repeat for the second lead and wire.
  • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
  • For more information, please refer to this soldering guide.
Agregar Comentario
Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
  • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
Agregar Comentario
Lift the motor out of the bracket.
  • Lift the motor out of the bracket.
  • Remember to not pull by the wires! This can make your repair a lot more complicated.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Sean Michel
Miembro Desde 14/01/13
1,229 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 19-44, Regan Winter 2013 Miembro de Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 25
Últimos 30 Días: 90
Todo El Tiempo: 6,214
