Saltar al contenido principal
Nintendo Entertainment System Game Cartridge Tray Springs Replacement
Qué necesitas
  1. Nintendo Entertainment System Game Cartridge Tray Springs Replacement, Game Cartridge Tray: paso 1, imagen 1 de 2 Nintendo Entertainment System Game Cartridge Tray Springs Replacement, Game Cartridge Tray: paso 1, imagen 2 de 2
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
  2. Nintendo Entertainment System Game Cartridge Tray Springs Replacement: paso 2, imagen 1 de 2 Nintendo Entertainment System Game Cartridge Tray Springs Replacement: paso 2, imagen 2 de 2
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
  3. Nintendo Entertainment System Game Cartridge Tray Springs Replacement: paso 3, imagen 1 de 3 Nintendo Entertainment System Game Cartridge Tray Springs Replacement: paso 3, imagen 2 de 3 Nintendo Entertainment System Game Cartridge Tray Springs Replacement: paso 3, imagen 3 de 3
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  4. Nintendo Entertainment System Game Cartridge Tray Springs Replacement: paso 4, imagen 1 de 2 Nintendo Entertainment System Game Cartridge Tray Springs Replacement: paso 4, imagen 2 de 2
    • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
    • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
  5. Nintendo Entertainment System Game Cartridge Tray Springs Replacement, Game Cartridge Tray Springs: paso 5, imagen 1 de 1
    • Push down on the spring with your finger and pull out of the plastic casing.
    • If only one spring is worn out, replace only that spring.
Conclusión
3 personas más completaron esta guía.
nicholasweiser
Miembro Desde 09/22/10
2,634 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-40, Forte Fall 2010 Miembro de Cal Poly, Team 14-40, Forte Fall 2010
CPSU-FORTE-F10S14G40
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 26
Ultimos 30 días: 72
Todo El Tiempo: 10,737
