Saltar al contenido principal
Nikon D70 Memory Compression Board Replacement
Qué necesitas
  1. Nikon D70 Memory Compression Board Replacement, Battery: paso 1, imagen 1 de 1
    • Use your finger tip to pull the battery release tab toward the center of the D70.
    • Open the battery door and rotate it away from the bottom cover.
  2. Nikon D70 Memory Compression Board Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of the D70.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon D70 Memory Compression Board Replacement, Bottom Cover: paso 3, imagen 1 de 1
    • Remove the following eight screws securing the bottom cover to the D70:
    • Six 5.8 mm Phillips screws
    • One 10.7 mm Phillips screws
    • One 8.2 mm Phillips screws
  4. Nikon D70 Memory Compression Board Replacement: paso 4, imagen 1 de 2 Nikon D70 Memory Compression Board Replacement: paso 4, imagen 2 de 2
    • Carefully pull the bottom cover to separate it from the body of the D70.
    • Remove the bottom cover from the D70.
  5. Nikon D70 Memory Compression Board Replacement, Memory Compression Board: paso 5, imagen 1 de 3 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: paso 5, imagen 2 de 3 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: paso 5, imagen 3 de 3
    • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
    • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
    • Be sure you are prying up the retaining flap, not the socket.
    • Pull the ribbon cable straight out of its socket.
  6. Nikon D70 Memory Compression Board Replacement: paso 6, imagen 1 de 1
    • Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
    • It is not necessary to completely remove this piece of tape.
  7. Nikon D70 Memory Compression Board Replacement: paso 7, imagen 1 de 3 Nikon D70 Memory Compression Board Replacement: paso 7, imagen 2 de 3 Nikon D70 Memory Compression Board Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
    • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
    • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
  8. Nikon D70 Memory Compression Board Replacement: paso 8, imagen 1 de 1
    • Be sure not to lose the small iron core around the DC-In ribbon cable.
  9. Nikon D70 Memory Compression Board Replacement: paso 9, imagen 1 de 1
    • Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
  10. Nikon D70 Memory Compression Board Replacement: paso 10, imagen 1 de 1
    • Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
  11. Nikon D70 Memory Compression Board Replacement: paso 11, imagen 1 de 2 Nikon D70 Memory Compression Board Replacement: paso 11, imagen 2 de 2
    • Grab the memory compression board by its edges at the position shown in the first picture.
    • Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 23,773
