Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the four ZIF ribbon cables highlighted in red by using the following procedure: Use your fingernail to flip up the ZIF cable retaining flap on each socket. Be sure you are prying up the retaining flap, not the socket.
  • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
  • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
  • Be sure you are prying up the retaining flap, not the socket.
  • Pull the ribbon cable straight out of its socket.
Insertar traducción aquí
