Saltar al contenido principal
Nexus 9 USB Daughterboard Replacement
Qué necesitas
  1. Nexus 9 USB Daughterboard Replacement, Rear Case: paso 1, imagen 1 de 3 Nexus 9 USB Daughterboard Replacement, Rear Case: paso 1, imagen 2 de 3 Nexus 9 USB Daughterboard Replacement, Rear Case: paso 1, imagen 3 de 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 USB Daughterboard Replacement, Vibrator Daughterboard: paso 2, imagen 1 de 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 USB Daughterboard Replacement: paso 3, imagen 1 de 2 Nexus 9 USB Daughterboard Replacement: paso 3, imagen 2 de 2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 USB Daughterboard Replacement: paso 4, imagen 1 de 3 Nexus 9 USB Daughterboard Replacement: paso 4, imagen 2 de 3 Nexus 9 USB Daughterboard Replacement: paso 4, imagen 3 de 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 USB Daughterboard Replacement: paso 5, imagen 1 de 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 USB Daughterboard Replacement, USB Daughterboard: paso 6, imagen 1 de 1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
Conclusión
3 personas más completaron esta guía.
Geoff Wacker
Miembro Desde 09/30/13
89,961 Reputación
89 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 15
Todo El Tiempo: 3,566
