Saltar al contenido principal
Motorola Edge (2022) Camera Bezel Replacement
Qué necesitas
  1. Motorola Edge (2022) Camera Bezel Replacement, Heat the right edge: paso 1, imagen 1 de 1
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: paso 2, imagen 1 de 2 Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: paso 2, imagen 2 de 2
    • Insert an opening pick between the camera bezel and the back cover.
  3. Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: paso 3, imagen 1 de 2 Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: paso 3, imagen 2 de 2
    • Slide the pick around the perimeter of the camera bezel to slice all the adhesive securing the bezel.
    • You may have to repeat this process multiple times to completely cut all of the adhesive.
  4. Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: paso 4, imagen 1 de 2 Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: paso 4, imagen 2 de 2
    • Lift the camera bezel away from the phone and remove it.
Conclusión
To reassemble your device, follow the instructions in reverse order.
Spencer Day
Miembro Desde 09/14/22
55,203 Reputación
408 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,430 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 338
