Saltar al contenido principal
MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement
Qué necesitas
  1. MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement, Lower Case: paso 1, imagen 1 de 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement: paso 2, imagen 1 de 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement, Battery Connector: paso 3, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement, Battery Connector: paso 3, imagen 2 de 2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement: paso 4, imagen 1 de 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: paso 5, imagen 1 de 1
    • Use the flat end of a spudger to lift the AirPort/Bluetooth connector out of its socket on the logic board.
  6. MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement: paso 6, imagen 1 de 1
    • Peel back the piece of EMI tape covering the AirPort/Bluetooth cable on the AirPort/Bluetooth housing.
  7. MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement: paso 7, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement: paso 7, imagen 2 de 2
    • Use the flat end of a spudger to gently lift the AirPort/Bluetooth connector out of its socket on the AirPort/Bluetooth board.
    • Remove the cable from your MacBook.
Conclusión
16 personas más completaron esta guía.
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,298 Guías creadas
5 comentarios
Is there a way to diagnose if the on and off bluetooth on my MacBook Pro Mid 2012 is related to a frayed Bluetooth cable vs a broken Bluetooth board?
Mina G. - Contestar
I also have the same MacBook Pro. I just swapped the board and it didn’t fix my Bluetooth issue. It’s probably the cable.
Craig Arn -
I’d call this an easy replacement to be honest. Pulling the tape back is the hardest part. I didn’t disconnect the battery for mine (as some reviews said that could cause shorts as much as not disconnecting it), and things went just fine. All together, replacement took me less than 10 minutes from start to end, and things work great now!
John Kidd - Contestar
This was an easy fix. I bought the cable & the bt/wifi card, but turned out only the cable was faulty.
Egbert Kappert - Contestar
WARNING :
Be really careful both while installing the cable : I did a replacement a few weeks ago, which turned to be a real failure, there was so much stress applied between both the board and the cable, that it started to extend and so, ripped the micro wires inside, and so wifi on my Mac was completely screwed up.
Be also aware of the different cables existing for this model. Just bought one form eBay, it was way too long for my mid-2012, I managed to make it work anyway using some tape, hopefully this fix will last.
A.R - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 49
Todo El Tiempo: 16,931
