Saltar al contenido principal
MacBook Pro 13" Unibody Mid 2010 Feet Replacement
Qué necesitas
  1. MacBook Pro 13" Unibody Mid 2010 Feet Replacement, Remove the lower case screws: paso 1, imagen 1 de 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2010 Feet Replacement, Lift the lower case away: paso 2, imagen 1 de 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2010 Feet Replacement, Feet: paso 3, imagen 1 de 3 MacBook Pro 13" Unibody Mid 2010 Feet Replacement, Feet: paso 3, imagen 2 de 3 MacBook Pro 13" Unibody Mid 2010 Feet Replacement, Feet: paso 3, imagen 3 de 3
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 13" Unibody Mid 2010 Feet Replacement: paso 4, imagen 1 de 1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 13" Unibody Mid 2010 Feet Replacement: paso 5, imagen 1 de 1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 13" Unibody Mid 2010 Feet Replacement: paso 6, imagen 1 de 1
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 13" Unibody Mid 2010 Feet Replacement: paso 7, imagen 1 de 3 MacBook Pro 13" Unibody Mid 2010 Feet Replacement: paso 7, imagen 2 de 3 MacBook Pro 13" Unibody Mid 2010 Feet Replacement: paso 7, imagen 3 de 3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 13" Unibody Mid 2010 Feet Replacement: paso 8, imagen 1 de 1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
Conclusión
25 personas más completaron esta guía.
Adam O'Camb
Miembro Desde 04/11/15
196,326 Reputación
416 Guías creadas
2 comentarios
Just wondering if melting the original pads from inside the case with a flame would help to fix them in place for a little longer.
vlada - Contestar
I’d be a little wary of doing something like that. I don’t think it would help the pads stay in place very much, but it might make it really hard to clean the case when you do want to replace the pads. If you want to make the original pads last a little longer you can try pulling them off, cleaning off the old adhesive, and applying some new tape or glue.
Adam O'Camb -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 6,835
