Introducción
You can install hard drives up to 9.5mm thick.
Qué necesitas
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
Remove the two black T8 Torx screws securing the silver bracket to the hard drive.
867 personas más completaron esta guía.
30 comentarios
This upgrade is so easy. Just do it. Even your dad could do this.
After the upgrade to a 320 GB 7200 rpm, the MacBook (1.83 GHz Intel Core Duo A1181, with 2 GB of ram) works like a new computer. However, the fan comes on so easy - and stays on forever. Is this due to the increased speed of the hard drive? Is there a way to turn down the hard drive speed when used on AC power?
The rubber guide came off on mine too. The mistake is that the screws without the flanges go on the outside edge of the Mac and the flange ones towards the inside. If you do it backwards it will pull the rubber guide off and then an otherwise effortless install will take a while longer to complete.
it's really easy to do this - there's no need to pay someone else! thanks for this awesome tutorial.
Very simple and easy! The biggest challenge was the walk to Radio Shack in cold weather to go get a !#!@ torx! The OSX installation guide was also a big help.
Bought a Crucial M4 CT128M4SSD2 (128 GB SSD), removal was quick and easy. This was my wife's mac, I personally do not own Apple products. My challenge was that I had to erase the drive (which in the process re-formats the ssd) which got the install up and running.
