Saltar al contenido principal
MSI GS63VR 6RF Stealth Pro Battery Replacement
Qué necesitas
  1. MSI GS63VR 6RF Stealth Pro Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Phillips screwdriver to remove the 15 screws securing the back cover.
    • Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
    • Do not insert the opening too too far into the back edge (with "Stealth" written on it), or you may damage the power LED.
    • The back cover is secured with clips. Too much pressure from the spudger can break the clips, but some flex is not dangerous.
    • Remove the back cover.
  2. MSI GS63VR 6RF Stealth Pro Battery Replacement: paso 2, imagen 1 de 1
    • Disconnect the battery by carefully pulling its connector towards the battery.
    • Pull parallel to the battery, not straight up.
  3. MSI GS63VR 6RF Stealth Pro Battery Replacement: paso 3, imagen 1 de 2 MSI GS63VR 6RF Stealth Pro Battery Replacement: paso 3, imagen 2 de 2
    • The battery is attached to the laptop with a strong adhesive.
    • Lift the battery from laptop.
    • Be careful not to bend the or puncture the battery, as that may cause a fire hazard.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 26
Todo El Tiempo: 6,615
