Saltar al contenido principal
Lenovo Yoga 710-14ISK Battery Replacement
Qué necesitas
  1. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover screws: paso 1, imagen 1 de 1
    • Remove the M2 × 7 mm, Torx-head screws.
    • Remove the M2 × 5 mm, Torx-head screws.
  2. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: paso 2, imagen 1 de 2 Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: paso 2, imagen 2 de 2
    • Insert a prying tool (opening pick) between the base cover and the cover and slide it in the direction shown by arrows to separate the base cover from the cover.
    • Remove the base cover.
  3. Lenovo Yoga 710-14ISK Battery Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Unplug the battery connector.
    • Remove the M2 × 3 mm, Phillips-head screws.
    • Remove the battery pack.
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Miembro Desde 04/22/20
40,298 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,243 Guías creadas
Un comentario
Hi, do i can replace my laptop battery by myself? or i should go to geek squad in best buy.
Jesse Milani - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 24
Todo El Tiempo: 644
