Saltar al contenido principal
Lenovo Yoga 2 13" Battery Replacement
Qué necesitas
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: paso 2, imagen 1 de 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: paso 4, imagen 1 de 1
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: paso 6, imagen 1 de 1
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
Conclusión
12 personas más completaron esta guía.
Nichelle
Miembro Desde 03/11/15
1,550 Reputación
5 Guías creadas
Equipo
Marist, Team 1-2, Laflen Spring 2015 Miembro de Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 60
Todo El Tiempo: 31,674
