Saltar al contenido principal
Lenovo ThinkPad T580 Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo ThinkPad T580 Wi-Fi Card Replacement, External Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, External Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, External Battery: paso 1, imagen 3 de 3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 2, imagen 3 de 3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 3, imagen 3 de 3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Wi-Fi Card Replacement, Bottom Case: paso 4, imagen 1 de 2 Lenovo ThinkPad T580 Wi-Fi Card Replacement, Bottom Case: paso 4, imagen 2 de 2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 5, imagen 3 de 3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 6, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 6, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 6, imagen 3 de 3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Wi-Fi Card Replacement, Internal Battery: paso 7, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 8, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 8, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 8, imagen 3 de 3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 Wi-Fi Card Replacement, Wi-Fi Card: paso 9, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, Wi-Fi Card: paso 9, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, Wi-Fi Card: paso 9, imagen 3 de 3
    • Using a spudger, pop off the gray and black coaxial cables from the Wi-Fi card.
  10. Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 10, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 10, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 10, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the 3.6 mm screw from the Wi-Fi card.
  11. Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 11, imagen 1 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 11, imagen 2 de 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: paso 11, imagen 3 de 3
    • Slide the Wi-Fi card out from the socket on the motherboard.
Conclusión
Austin Blakely
Miembro Desde 03/11/19
19,646 Reputación
53 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,410 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 867
