Saltar al contenido principal
Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove base cover: paso 1, imagen 1 de 1
    • Remove the 7 screws holding the base cover in place.
    • Remove the base cover.
  2. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Unplug the battery: paso 2, imagen 1 de 1
    • Peel up the insulated sheet from the battery connector.
    • Unplug the battery connector in the direction showed by the arrow.
  3. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery screws: paso 3, imagen 1 de 1
    • Remove the two M2 × L4 mm, flat-head screws.
    • Remove the two M2 × L5 mm, flat-head, screws.
  4. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery: paso 4, imagen 1 de 1
    • Remove the battery.
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Max Kletskov
Miembro Desde 04/22/20
40,307 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,288 Guías creadas
3 comentarios
Great Thank you for info
Brad - Contestar
Will this battery generate a Bios not authentic battery warning? Other replacement batteries would not charge in my P1 Gen2 ThinkPad.
hello - Contestar
Is it compatible for Lenovo Thinkpad P1 Gen1 Type 20MD ?
k2ki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 75
Ultimos 30 días: 353
Todo El Tiempo: 11,101
