Saltar al contenido principal
Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: paso 1, imagen 2 de 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 2 de 2
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: paso 5, imagen 2 de 2
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
82,722 Reputación
202 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,439 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 29
Ultimos 30 días: 59
Todo El Tiempo: 1,073
