Saltar al contenido principal
Lenovo IdeaPad S340-15IWL CMOS Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: paso 3, imagen 1 de 3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: paso 3, imagen 2 de 3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: paso 3, imagen 3 de 3
    • Remove the circular CMOS battery on the far left side of the computer by lifting it with your finger or an opening tool.
    • This is only attached with adhesive, so it does not require extensive force.
  4. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: paso 4, imagen 2 de 2
    • Unplug the bundled red and black wires connecting the CMOS battery to the side of the device.
    • Remove the CMOS battery from the laptop.
Conclusión
2 personas más completaron esta guía.
Kristen Gismondi
Miembro Desde 11/12/14
82,368 Reputación
200 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,303 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 23
Ultimos 30 días: 137
Todo El Tiempo: 1,643
