Saltar al contenido principal
Lenovo IdeaPad Flex 5-1570 Touchpad Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 2, imagen 1 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 2, imagen 2 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 2, imagen 3 de 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 3, imagen 2 de 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: paso 4, imagen 1 de 2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 5, imagen 3 de 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: paso 6, imagen 1 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: paso 6, imagen 2 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: paso 6, imagen 3 de 3
    • Using the plastic opening tool, unlock the four ZIF connectors to release the flat cables.
    • Disconnect the four flat cables from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 7, imagen 1 de 1
    • Using the JIS #000 screwdriver, remove six 2mm screws holding the trackpad down to the device.
  8. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 8, imagen 1 de 1
    • Using the plastic opening tool, remove the silver piece of tape holding the touchpad to the device.
  9. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 9, imagen 1 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 9, imagen 2 de 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: paso 9, imagen 3 de 3
    • Insert the plastic opening tool underneath the touchpad.
    • Lift it up and remove the touchpad from the device.
Conclusión
Justin Ogihara
Miembro Desde 09/18/17
27,253 Reputación
52 Guías creadas
Equipo
EDU Team Miembro de EDU Team
Staff
7 Miembros
640 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 43
Todo El Tiempo: 1,462
