Introducción
This guide will detail the steps necessary to remove the keyboard from the Lenovo Essential G560 laptop. Please note that this is not an easy process and may take a bit of patience, especially when reinstalling or installing the new keyboard.
Partes
No se requieren partes.
Turn off the computer.
  • Turn off the computer.
  • Disconnect the charging cable from the computer.
  • Failure to unplug the cable could result in electric shock.
  • Flip the computer upside down.
Agregar Comentario
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Agregar Comentario
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Agregar Comentario
Remove the seven 5.3 mm Phillips  #1 screws holding the back panel in place.
  • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly. If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
  • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
Agregar Comentario
The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Agregar Comentario
Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
  • Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
  • Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
Agregar Comentario
Flip the computer over.
  • Flip the computer over.
  • Using the plastic opening tool, push in the four small, plastic tabs located at the top of the keyboard.
Agregar Comentario
Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
  • Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
  • While this step can be accomplished using your hand, it may be easier to use a spudger or plastic opening tool.
Agregar Comentario
Lift the keyboard up from the bezel.
  • Lift the keyboard up from the bezel.
  • Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
  • Carefully pull the keyboard cable from its socket.
  • Be very careful while unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
This step need more detailed explanation
(with additional pictures) because it
crucial.
Anthony
Anthony Pek - Contestar
Conclusión
10 personas más completaron esta guía.
Dennis Wong
Miembro Desde 11/01/13
468 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 18-40, Regan Winter 2013 Miembro de Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Miembros
7 Guías creadas
Thank you frndzz
Anand krishnan - Contestar
Thank you frndz
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 17
Últimos 30 Días: 87
Todo El Tiempo: 15,555
