Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 2
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly. If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
  • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
Insertar traducción aquí
