Saltar al contenido principal
LG VX5200 LCD Screen Replacement
Qué necesitas
  1. LG VX5200 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 LG VX5200 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the phone on its back.
  2. LG VX5200 LCD Screen Replacement: paso 2, imagen 1 de 2 LG VX5200 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 LCD Screen Replacement: paso 3, imagen 1 de 2 LG VX5200 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 LCD Screen Replacement, Face Plate: paso 4, imagen 1 de 3 LG VX5200 LCD Screen Replacement, Face Plate: paso 4, imagen 2 de 3 LG VX5200 LCD Screen Replacement, Face Plate: paso 4, imagen 3 de 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 LCD Screen Replacement: paso 5, imagen 1 de 3 LG VX5200 LCD Screen Replacement: paso 5, imagen 2 de 3 LG VX5200 LCD Screen Replacement: paso 5, imagen 3 de 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 LCD Screen Replacement: paso 6, imagen 1 de 3 LG VX5200 LCD Screen Replacement: paso 6, imagen 2 de 3 LG VX5200 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 LCD Screen Replacement, LCD Screen: paso 7, imagen 1 de 2 LG VX5200 LCD Screen Replacement, LCD Screen: paso 7, imagen 2 de 2
    • Try not to move the thin component wires as they will bend and break very easily.
  8. LG VX5200 LCD Screen Replacement: paso 8, imagen 1 de 3 LG VX5200 LCD Screen Replacement: paso 8, imagen 2 de 3 LG VX5200 LCD Screen Replacement: paso 8, imagen 3 de 3
    • Remove the white stopper from the camera light located above the gold connector.
    • Lift the gold connector up with your finger to detach it.
  9. LG VX5200 LCD Screen Replacement: paso 9, imagen 1 de 1
    • Gently lift out the speaker with your fingertip.
  10. LG VX5200 LCD Screen Replacement: paso 10, imagen 1 de 3 LG VX5200 LCD Screen Replacement: paso 10, imagen 2 de 3 LG VX5200 LCD Screen Replacement: paso 10, imagen 3 de 3
    • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
    • Gently remove the vibrator with tweezers.
    • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
  11. LG VX5200 LCD Screen Replacement: paso 11, imagen 1 de 2 LG VX5200 LCD Screen Replacement: paso 11, imagen 2 de 2
    • Place phone body and LCD screen on a clean, lint-free surface.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 4-13, Forte Winter 2010 Miembro de Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,841
